Error in building HBzones
Hi everybody
Can you please help me through
I have got this simple problem after updating Honeybee and Ladybug with update component.
what should I do to fix the problem?
thanks a lot
MINE2.gh (456 KB)
Hi farzane,
your HBzone is not closed, you have a ‘Null Brep’ in this part here:
You are right about the error message, in fact I have modified some HB HB lines to run the component.
The lines are:
I have closed your HBzone and managed the exception and your file works fine. About the exception I have to ask to Mostapha and Chris.
Best
Antonello
Hi Antonello, Is this a bug or a user error? We’re releasing a new version and I want to make sure that we will have this one fixed if this is a bug.
Thank you so much Antonello
In fact I used Chris’s file (honeybee energy modeling) to create hbzones by myself and before updating everything was fine but after new version I got this error.
Farzane, Antonello, and Mostapha,
This was code that I had added in yesterday to fix a very rare bug but it apparently created several much more common bugs. I have removed it and everything should be back to normal:
https://github.com/mostaphaRoudsari/Honeybee/commit/d34f5e23bb2c7bb…
Sorry for the inconvenience here.
-Chris
Now everything is perfect…
Thanks a lot Chris
