Error in radiation component description
I think there is an error in the component description of RTRadiationAnalysis. Hovering over radiation result gives units of ‘Wh/m2’.
However, the magnitude of results being outputted from this component seem far too small to be in Wh/m2. Should it be kWh/m2?
As a comparison, the output ‘radiationOutput’ in component ‘radiationAnalysis’ returns values in kWh/m2 too, which is why I think it should be kWh/m2 in both components.
Hi James, Thank you for letting us know. This is indeed a bug. The units of the results are the same as the original component. It is fixed now.
