I have a problem with “Honeybee_Glazing based on ratio” component. Whenever I open my file, this competent gives me the following error and does not work until I replace the component again. So, whenever I reopen the file, I should replace this component for simulation.
Error: 1. Solution exception:name ‘EPConstructions_’ is not defined
it should be noted that No construction is attached to the component.
I do not know what the problem is and how I can solve it. Does anybody have an idea for that ?
From the attached image it looks like the error is related to how you are making your HBZones. Can you share the GH file with geometry internalized? I could take a look.
Thank you for your reply. Attached you can find GH file. Every time I open this file, I have to replace the “Honeybee_Glazing based on ratio” component with a new one.
Thank you. I know reinserting this component solve the problem. But every time which I open this file, It gives me this error and I have to reinsert this component. I want to know the main problem. It also happen for some other components.
