Error on daylight analysis
hi,i dont know whats wrong with my brep,can anyone help me?
kimia.gh (553 KB)
Hi Kimia,
Honey bee cannot read breps (1, 2, 3) correctly, on the picture below: a b c
Try to draw roofs and ground floors of them as single surfaces, so your file works correctly.
Bests
Antonello
thanks antoni,my problem is that my breps are parametric(drawn in grass not rhino) so i can find better form for total daylight of my building i dont know whats the problem with breps 1-2-3- i made them the same way i did for others:( if i draw it in rhino it wont be parametric form anymore and i cant search for better form:( do you have any idea have can i fix brep 1-2-3- without baking them in rhino
Hi Kimia,
Firstly, I’m sorry, the breps are 2, 3 and 4 and not 1, 2, 3 that I wrote yesterday.
I suggest that you fix your issue before making your definitive brep, but if it is not possible you can follow the possible method showed below.
BEFORE
AFTER
Bests
Antonello
thank you so much :slight_smile:
