Hi
I’m Getting this Error from “HB Model To OSM” component :
Program Version,EnergyPlus, Version 9.4.0-998c4b761e, YMD=2021.05.30 15:12,
** Severe ** <root>[Construction:AirBoundary][Generic Air Boundary][radiant_exchange_method] - "0" - Failed to match against any enum values.
** Severe ** <root>[Construction:AirBoundary][Generic Air Boundary][solar_and_daylighting_method] - "None" - Failed to match against any enum values.
** Warning ** Version: in IDF="9.5" not the same as expected="9.4"
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
...Summary of Errors that led to program termination:
..... Reference severe error count=2
..... Last severe error=<root>[Construction:AirBoundary][Generic Air Boundary][solar_and_daylighting_method] - "None" - Failed to match against any enum values.
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error -- final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
************* EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 2 Severe Errors; Elapsed Time=00hr 00min 0.19sec
Runtime error (PythonException): ** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
Traceback:
line 244, in script
However i’m using the sample file “single_family_energy_model.gh” without changing anything
HB Version 1.2 and after running “LB Sync Grasshopper File” & “LB Versioner” it become 1.2.1
