Hello all,
I have some strange error using the example file for honeybee plus. Simulation finished and ase works as well. Having problem with sDA which complains about input file format. Any ideas? Many thanks.
Hello all,
Thank you for your help! All results are in the same folder. The ASE is reading result from the same folder which works ok but not the other annual metrics. Simulation finished alright so not PATH or RAYPATH I guess.
