Error when running E+
when I run this multizone model without deconstructing faces, E+ runs well.
But when I deconstruct the solids to assign materials and apertures I get this error message even though the model is valid:
Runtime error (EncoderFallbackException): ‘ascii’ codec can’t encode character ‘\u2026’ in position 110: ordinal not in range(128)
Traceback:
line 193, in script
Could anybody help me to find the mistake?
Thanks in advance.
PC
viv_int_ult_resumen_12.gh (433.3 KB)
Error found: a letter “ñ” among the names
Thanks anyway.
PC
Hi @PatriciaEdithCampore ,
Thanks for reporting and I would consider this a bug in our code that’s related to the character encodings that you have on your machine. This is not something that should block you from running the simulation and I have a fix ready on my machine that’s getting the simulation to run.
I’ll post back here once I update the component with the fix.
FYI, you probably are already aware of this but the model in your file was not passing validation:
But, if you correct some of those interior constructions, it can simulate correctly.
FYI, @PatriciaEdithCampore ,
I have merged a fix to the component that will avoid this encoding error in the future:
You can get the updated “Model To OSM” component now with the LB Versioner.
Great @chris !
Thanks a lot.
PC
