I got it rectified the error related to weather file through providing a URL entry. But now am getting new error.
Current document units is in Millimeters
Conversion to Meters will be applied = 0.001
[1 of 8] Writing simulation parameters…
[2 of 8] No context surfaces…
[3 of 8] Writing geometry…
One of the surfaces has less than 3 identical coordinates and is removed.
[4 of 8] Writing Electric Load Center - Generator specifications …
[5 of 8] Writing materials and constructions…
[6 of 8] Writing schedules…
[7 of 8] Writing loads and ideal air system…
[8 of 8] Writing outputs…
… idf file is successfully written to : c:\ladybug\unnamed\EnergyPlus\unnamed.idf
Analysis is running!..
Done! Read below for errors and warnings:
Program Version,EnergyPlus, Version 9.0.1-bb7ca4f0da, YMD=2019.07.04 12:42,
************* Beginning Zone Sizing Calculations
** Severe ** CheckConvexity: Surface=“ZONE_0_SRF_0” is non-planar.
** ~~~ ** Coincident Vertices will be removed as possible.
** ~~~ ** ( 0.005, 0.005, 0.003)
** ~~~ ** ( 0.005, 0.005, 0.000)
** ~~~ ** ( 0.012, 0.005, 0.000)
** Severe ** CheckConvexity: Surface=“ZONE_0_SRF_1” is non-planar.
** ~~~ ** ( 0.012, 0.005, 0.003)
** ~~~ ** ( 0.012, 0.012, 0.000)
** Severe ** CheckConvexity: Surface=“ZONE_0_SRF_2” is non-planar.
** ~~~ ** ( 0.012, 0.012, 0.003)
** ~~~ ** ( 0.005, 0.012, 0.000)
** Severe ** CheckConvexity: Surface=“ZONE_0_SRF_3” is non-planar.
** ~~~ ** ( 0.005, 0.012, 0.003)
** Warning ** GetHTSurfaceData: Surfaces with interface to Ground found but no “Ground Temperatures” were input.
** ~~~ ** Found first in surface=ZONE_0_SRF_4
** ~~~ ** Defaults, constant throughout the year of (18.0) will be used.
** Severe ** CheckConvexity: Surface=“ZONE_0_SRF_4” is non-planar.
** Severe ** CheckConvexity: Surface=“ZONE_0_SRF_5” is non-planar.
** Warning ** GetSurfaceData: Very small surface area[1.05000E-005], Surface=ZONE_0_SRF_0
** Warning ** GetSurfaceData: Very small surface area[1.05000E-005], Surface=ZONE_0_SRF_1
** Warning ** GetSurfaceData: Very small surface area[1.05000E-005], Surface=ZONE_0_SRF_2
** Warning ** GetSurfaceData: Very small surface area[1.05000E-005], Surface=ZONE_0_SRF_3
** Warning ** GetSurfaceData: Very small surface area[2.45000E-005], Surface=ZONE_0_SRF_4
** Warning ** GetSurfaceData: Very small surface area[2.45000E-005], Surface=ZONE_0_SRF_5
** Warning ** GetSurfaceData: There are 36 coincident/collinear vertices; These have been deleted unless the deletion would bring the number of surface sides < 3.
** ~~~ ** For explicit details on each problem surface, use Output:Diagnostics,DisplayExtraWarnings;
** Severe ** GetSurfaceData: There are 18 degenerate surfaces; Degenerate surfaces are those with number of sides < 3.
** ~~~ ** These surfaces should be deleted.
** Warning ** CalculateZoneVolume: 1 zone is not fully enclosed. For more details use: Output:Diagnostics,DisplayExtrawarnings;
** Warning ** CheckUsedConstructions: There are 1 nominally unused constructions in input.
** ~~~ ** For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings;
** Warning ** ComputeIntSWAbsorbFactors: Sum of area times inside solar absorption for all surfaces is zero in Zone: ZONE_0
** Warning ** Zone areas*inside surface emissivities are summing to zero, for Zone=“ZONE_0”
** ~~~ ** As a result, MRT will be set to MAT for that zone
** Warning ** Calculated design cooling load for zone=ZONE_0 is zero.
** ~~~ ** Check Sizing:Zone and ZoneControl:Thermostat inputs.
** Warning ** Calculated design heating load for zone=ZONE_0 is zero.
** Warning ** ManageSizing: For a plant sizing run, there must be at least 1 Sizing:Plant object input. SimulationControl Plant Sizing option ignored.
************* Testing Individual Branch Integrity
************* All Branches passed integrity testing
************* Testing Individual Supply Air Path Integrity
************* All Supply Air Paths passed integrity testing
************* Testing Individual Return Air Path Integrity
************* All Return Air Paths passed integrity testing
************* No node connection errors were found.
************* Beginning Simulation
************* Simulation Error Summary *************
** Warning ** The following Report Variables were requested but not generated – check.rdd file
** ~~~ ** Either the IDF did not contain these elements, the variable name is misspelled,
** ~~~ ** or the requested variable is an advanced output which requires Output : Diagnostics, DisplayAdvancedReportVariables;
************* Key=*, VarName=COOLING COIL ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=CHILLER ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=BOILER GAS ENERGY, Frequency=Hourly
************* Key=*, VarName=HEATING COIL TOTAL HEATING ENERGY, Frequency=Hourly
************* Key=*, VarName=HEATING COIL GAS ENERGY, Frequency=Hourly
************* Key=*, VarName=HEATING COIL ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=HUMIDIFIER ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=FAN ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=ZONE VENTILATION FAN ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=EARTH TUBE FAN ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=PUMP ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=ZONE VRF AIR TERMINAL COOLING ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=ZONE VRF AIR TERMINAL HEATING ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=VRF HEAT PUMP COOLING ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=VRF HEAT PUMP HEATING ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=CHILLER HEATER SYSTEM COOLING ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=CHILLER HEATER SYSTEM HEATING ELECTRIC ENERGY, Frequency=Hourly
************* There are 1 unused schedules in input.
************* There are 1 unused week schedules in input.
************* There are 3 unused day schedules in input.
************* Use Output:Diagnostics,DisplayUnusedSchedules; to see them.
************* ===== Final Error Summary =====
************* The following error categories occurred. Consider correcting or noting.
************* Nominally Unused Constructions
************* …The nominally unused constructions warning is provided to alert you to potential conditions that can cause
************* …extra time during simulation. Each construction is calculated by the algorithm indicated in the HeatBalanceAlgorithm
************* …object. You may remove the constructions indicated (when you use the DisplayExtraWarnings option).
************* EnergyPlus Sizing Error Summary. During Sizing: 14 Warning; 6 Severe Errors.
************* EnergyPlus Completed Successfully-- 51 Warning; 24 Severe Errors; Elapsed Time=00hr 00min 1.06sec
Why?
