Rhino 6/Grasshopper. I’m reusing a year old recipe to do VSC that worked before, but doesn’t seem to run on the latest LB/HB. The run DaylightAnalysis component gives me error:
“1. Solution exception:Could not find file ‘C:\Simulation\ProjectName\VSC_Test\VSC\error.log’.”
I’m using legacy components but have [+] installed. I’ve tried installing/reinstalling several times. Tried attaching the file but cant due to new user. Can you help me?
Alex
Send a link to the file.
The geometry was not internalised.
LBPLUS_RH VSC w internalised data.gh (497.6 KB)
Sorry, try this one instead.
Can be that it was a mater of updating the components.
I did and it runs fine on my machine.
I simplified some values so please check the attached file …
LBPLUS_RH VSC w internalised data_AY.gh (513.3 KB)
Thanks! I’m still getting the same error, Solution Exception. I guess it must be something with my installation.
Hi again, I figured out what I did wrong: I had Radiance installed in the default folder and not in C:\Radiance. Thanks for your time!
