Hi Everyone,
I’m new on Ladybug + Honeybee and this is happening with some of my components.
Hi Everyone,
Thank you Mohammed, but I follew all these instrucstions and still doesn’t work!
Luiza,
Did you install and check the GhPython in the grasshopper components folder?
Right-click the GhPython file >> in Properties >> make sure there is no “blocked” text (select"unblock").
For more info see Mostapha’s post like this issue.
-Omid
Thank you Omid! I’ll try that
The GhPython 0.6.0.3 wasn’t working, had to download the earlier version
