Example daylight analysis stopped working
I recently downloaded and example file to test out some daylight analysis from hydra:
There is an error wit honeybee stating that it failed to load the therm setting. However, in the first few minutes of me opening the example file everything worked fine even with this error since i dont think i require therm for this example. About 10 minutes later the analysis stopped working.
with a eroror code stating:
  1. Solution exception:Failed to read the results!
I am not sure why this is happening.
Please run the updater and restart rhino. And update the example script and try.
how do i run the updater?
I re-downloaded the newest update and that seemed to work, thank you
