Hi everyone. In the legacy version, it seems that a zone can be excluded from total floor area calculation through the ‘part of area’ in the ‘set zone properties’. However, such function cannot be found in LBT 1.4.0. How can I do that? I’d appreciate it if you could help me.
You’ll have to be more specific, @wooseung . In which calculation are you trying to exclude a room’s floor area? There are lots of calculations throughout honeybee where the floor area is used.
Thank you @chris for your answer. I would like to get a HVAC EUI of a building. But when assumed that there is a plenum space in the model, I would like to exclude the area of that plenum space from the EUI calculations.
Hi @wooseung ,
Thanks for clarifying and see now that you’re talking about this “part of total floor area” property on zones in EnergyPlus. I can see why this is useful and it’s something that should be integrated into the HB Plenum component along with also being exposed on one of the Honeybee 0::Create
components like the HB Set Story component. So I think we should natively support this in Honeybee and I opened an issue for it here:
It will take me a bit of time to implement but you can track the progress on that issue. In the meantime, here’s a custom GPython script that you can use to edit the OSM to exclude certain rooms from the floor area calculation.
manually_exclude_floor_area.gh (47.6 KB)
Thank you very much for opening the issue, @chris. The files that you have provided are also really great help to me.
I just wanted to say here that excluding the floor area is now officially supported natively in honeybee. There are a couple of ways that you can exclude the floor area for a given Room. One is with the “HB Set Multiplier” component, which now has an excl_floor_
input.
Another is with the “HB Plenum” component, which will now exclude the floor area of the Plenum by default unless include_floor_
is set to True
Excluding the floor area of a Room will affect both the EnergyPlus EUI output by the HB End Use Intensity component as well as the floor are of Models plugged into the “HB Geometry Properties” component.
Thanks again for bringing this up. Hopefully, this makes it easier to model buildings with a lot of plenum and attic spaces.
