I’m trying to export a GBxml file from rhino thanks to the DumpBGxml component. However even with the simplest geometry I get this error message: 1. Solution exception:Running OpenStudio CLI failed.
Are you able to upload a sample file that recreates the issue? Also, can you confirm that you get the same error when you try to use the HB Model to OSM component? That component should give you more information about how exactly OpenStudio failed.
Also, the following log file will have information about how this particular translation failed:
