Export to openstudio component "tuple" error
so the moment i run the simulation, i get an error of Solution exception:int() argument must be a string or numbernot “tuple”, like which input component might be causing this error ?
Uttam,
It’s hard to know without seeing what is connected to the OpenStudio component but this error is an indication that one of them is not the correct data type. Perhaps it’s the EnergySimPar? Again, it’s hard to know without seeing what is connected to the component.
@Chris Mackey, thank you for the response and i have figured out my problem :slight_smile:
