"exportToOpenStudio" component didn't work for curved geometry
Hi Mostapha and Chris,
I built curved geometries, just similar as you did in tutorials, and try to run an energy simulation test on it under default “energySimPar” settings. Finally it gave me a warning:
  1. The simulation has not run correctly because of this severe error:
    ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
the models are quite simple without “L” shape zones. so I try to set “0” to the “solarDistribution_” of “energySimPar” and run it again. this time the “exportToOpenStudio” component didn’t gave any error or warning, but the readEPResult component shows that it didn’t work.
I have no idea what could be the reason. Is it an energyplus problem or a openstudio problem or an honeybee problem? how to deal with it?
Thank you very much in advance!
GUO
GUO.X,
The CHKBKS warning happens any time you have a concave zone, which includes zone shapes that beyond those that are explicitly L-shaped so you are right to change the solar distribution here.
I don’t know why Openstudio is not generating a result file after this change. If you upload a GH file with the minimum components needed to recreate the situation, we can check out what is going on.
-Chris
Hi, Chris,
Thank you for your kind reply! Please find attached the GH file, thank you again for your time!
GUO
test-3.3dm (80.7 KB)
test-3.gh (585 KB)
GUO.X,
Everything is working on my end and the error does not seem to be the result of the curved geometry:
Are you still able to get the issue when you reopen the file or you update your components?
-Chris
test3_UPDATED.gh (559 KB)
Hi Chris,
Apologize for my late reply, and very surprised to find that the component works fine this time when I reopen it…
Anyway, grateful for your time, and it’s a great tool!
GUO
Glad it’s working! It was probably an issue with an older version of the component as the only thing I changed in the file I attached was updating everything.
