Firstly - thanks to all those responsible on the development of HB/Radiance etc.
I have a question - I am conducting a glare analysis and was wondering if it is possible to view the information that has been produced (as can be seen from the “falseClolour” image output) as Rhino Geometry?
So instead of an image file but if that can be actually plotted back into Rhino geometry and viewed?
the main reason for this request is to provide better visualisations - and hopefully better quality of the image.
Parse the sensors generated in step 1 into grasshopper as rays and shoot them against your geometry. Where it hits the geometry is the pixel that you see in your image.
Extract the colors / values from your image. You can use Grasshopper components for this but it also possible using Radiance itself.
Color the intersection points from step 2 based on the colors from step 3.
Now if you look from the exact same view in Rhino you should see something similar to your image. Of course when you change the view it will not be as nice since the points of intersections will not for a continuous geometry.
you need to create the mesh first then you use reColourMesh to color the mesh. If you want to only bring the image in Rhino as a 2D mesh then you should check Grasshopper’s image sampler.
