Hi, what type of tool can I used to assign properties (a fabric roller internal shade
It will depend on what you’re trying to use those blinds for. For instance, do you intend to use them in a daylight analysis or for an energy simulation?
Also, kindly setup a profile picture.
Thanks for your reply. Yes, I would like to use it for daylight analysis. I have these features from the manifacturer’s data sheet: thickness, emissivity, solar reflection, solar light transmission
In that case, I would recommend using LBNL windows to create a BSDF for the blinds and then use them in Honeybee.
