Facing issue with recolor mesh
I am doing annual daylight simulation and getting the results that are exceptionally less to be true value for DLA and UDLI. I feel the issue is somewhere in the recolor mesh component.
The value is in the range of 0-100lux.
Thank you in advance.
Hi Jay,
The units of DA and UDI are %, so results from 0-100 are correct. HB Annual Results to Data component will read the .ill results file and output hourly lux values for you across the year.
This website is good for understanding daylight metrics and how hourly lux values are used to generate the DA and UDI result Daylight Autonomy | Daylighting Pattern Guide
