Failed to creat case from folder
#1
Hi all!
I want to re-load a case and export probe locations and values,and it failed. Does anyone know how to fix this?
#2
Has to do with the stl file. Can you import the stl file to Rhino with no issues?
#3
There is nothing wrong when I import the stl file to Rhino.
#4
Hi @WuXue did you have any luck with this? Did rerunning the case help by any chance? You can also create a new case, with different name, and bring back the .stl to your older case. Not sure if that helps.
