When I am using stat file to estimate Ashrea climate Zone of a city , the file does not work.I downloaded the stat file from http://www.ladybug.tools/epwmap/.
I get the following erros from (import stat) component:
- Failed to find a heating design temperature in the stat file.
- Failed to find a cooling design temperature in the stat file.
Any ideas why this is happening ?
Hi @ParisaNadiri, and welcome to ladybug tools forum!
Could you please share a link of epwmap that you copied:
or your file to check it out.
BTW, you can use and copy and paste the link into the panel
, then, connect it to Ladybug_Open EPW And STAT Weather Files
component to download directly in GH .
Hi @OmidmRashidi,
thank you for your help.
I tired another way and it worked. The errors were due to the stat file that I downloaded. By weather Statistis and Conversion programe, I converted the epw file of the city to a stat file and it worked correctly.
