Hello everyone,
I’m trying to run a three phase grid based simulation for a box model and I’m running into the following error when I run the simulation:
Runtime error (Exception): Failed to load the results form an empty file: C:\Users\Sreejit Jayaram\Desktop\Test2\Results\Test_001\gridbased_threephase\result/SouthWindow…default.ill
Double check inputs and outputs and make sure everything is run correctly.
Traceback:
line 274, in set_values_from_file, “C:\Users\Sreejit Jayaram\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee\radiance\analysisgrid.py”
line 386, in results, “C:\Users\Sreejit Jayaram\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee\radiance\recipe\daylightcoeff\gridbased.py”
line 67, in script
Also, I have noticed that during the run, I’m seeing that the oconv warning (attached image below). Is this normal or am I missing something?
Thanks in advance !!
