I need to trigger a bake with a toggle, running into some problems:
- The geometry I’m trying to bake is 3DText and meshes from the Ladybug legend. Neither the Elefront nor the Human bake components seem able to bake the 3DText.
- The Heteroptera component “quick baker” bakes everything with no problems, but it can’t be triggered by a toggle unless you manually set the component to “activation lock” first. This must be repeated every time the file is opened.
My question is: does anyone know of an alternative to these components or have you found a way to bake Ladybug geometries with a toggle?
