Filter Surfaces Based on cut off Solar Irradiation Kwh/m2
I am trying to perform a solar analysis on a combination of surfaces to separate surfaces on the basis of kwh/m2 of solar irradiation. However, after filtering I get meshes, not the original surfaces. These meshes have a lot of faces and I cannot reconstruct my original surfaces which are receiving desired solar irradiation.
I found a script shared on this forum and it is good to sort the meshes but I am having trouble obtaining the original surfaces.
Could you please help me with how can I proceed and get my desired surfaces?
Thanks a lot!
Query1.gh (447.0 KB)
Can someone please have a look?
I don’t know if it is your need.
wow, yes I think it is what I have been trying to achieve. I’ll give it a go. Thank you so much Xiao!!
