Finding monthly average maximum and minimum temperature
Dear all,
I have been trying to determine the monthly average maximum and minimum temperature values using Ladybug. However, I am unable to obtain those values. I have tried different combinations of nodes but of no use. If someone can please help me, I’d highly appreciate it.
Thank you!
Bests
Question_avg_max-min_temp.gh (38.6 KB)
Hi, @Usman
I tried to make it, but I don’t know if that’s what you want.
Avg_max-min_temp.gh (53.6 KB)
That’s a good example there, @omen, and it gets the job done though you can avoid having to copy/paste the component so many times by just using a little help from Grasshopper data trees:
Alternatively, if you wanted to have a visualization of these max and min values, you can use the “percentile” capability of the LB Time Interval Operation component like so and still post-process the results to get the data that you care about:
Avg_max-min_temp_CWM.gh (31.9 KB)
That’s very cool. Thank you so much to both of you :slight_smile:
