- Solution exception:Failed to load the results form an empty file: C:\Users\PrGupta\OneDrive - NBBJ LP\PenPlace\Panelite Test\withPanelite\gridbased_fivephase\result/scene…default.ill
Double check inputs and outputs and make sure everything is run correctly.
There are no other errors along the script. Here are the things that we’ve tried:
- Using a different geometry
- Using a different weather file win_436_bsdf.xml (4.0 KB) panelite_bsdf.xml (826.6 KB)
- Using different directories
- Trying the script on two desktops (locally run)
Also, I am using BSDF files to define the glazing surfaces and not RGB values.
Running Radiance 5.3
Attaching the script, BSDF files and images of the error. (attached in a reply below)
