Hi, I have one zone in top of another, which means that they both have a shared floor/ceiling surface.
The construction for this shared construction is a concrete slab, a thick stone floor finish to provide some thermal mass, below the slab there is insulation and a drop down gypsum ceiling.
When creating the construction in HB for grasshopper I define it as follows:
- Layer 1 (Outmost): Stone finish
- Layer 2 : Slab
- Layer 3 : Air cavity
- Layer 4 : Insulation
- Layer 5 (Innermost) : Gypsum ceiling
My question is: how is EP going to interpret this. What are the innermost and outermost layers according to each of the zones? Or does EP maintain Layer 1 always on top (Z axis) and Layer 5 as the bottom layer (Z Axis).
(My logic tells me that for each zone, the innermost layer will be the stone finish, but this is not true).
It is important for me that the Floor finish is always on top so I capture solar radiation on it.
