Hello
I’m trying to do daylight analysis on a simple model. When I run PITGrid e GridRooms data I get a result. But when I run it with SensorGrid and GenPts I get a different result. I need to work with GenPts as I will run analyzes on different surfaces in the later stages of my work. Which result is correct, am I making a mistake? Are the two components different things? Can you help me? I am attaching the images and the file.
Thank you
Thanks for sharing your file. You have to flip the _geometry in GenPts. Your sensors are directed down (0, 0, -1), that’s why the illuminance is lower. Then you should of course also remove the negative expression in _offset_dist_.
