Currently trying to fix a small problem that I am absolutely no clue on how to fix.
The run settings of HB adaptive comfort won’t work on finding path to a folder that I’ve created. Which is weird because I have copy pasted the folder’s path properly. There was another topic about it that had the same problem due to the folder’s path that had been typed ended with a backslash and the solution was to remove said backslash at the ending. I had done the same without any good results. The same thing still happens when I removed the HB run settings, HB adaptive comfort still can’t find the proper path to folder that it’s supposed to default to.
Is there a proper way to type out the folder’s path or is there something that I had missed about the run settings?
