I need to develop a workflow that accommodates climate based annual metrics (sDA and ASE) together with energy simulation (heating and cooling loads). I understand that the first is done through HB+ while the second is done with HB legacy. I’m also aware that I can’t connect components between HB+ and HB legacy.
My main questions is what do you think the best approach would be? would building the zones twice (one for energy simulation and one for daylight simulation) work?
Has anyone come across this issue before?
I also need to connect the outputs of these to Colibri, does colibri work with outputs from both HB+ and HB together?
PS i’m not looking into lighting energy.
Thanks in advance
