HB Annual Daylight Recipe Visualize Output in LUX
An issue from our internal engineering team is that they want Annual Daylight visualized in the LB Spatial Heatmap component to be in Lux or Foot Candles. Currently the Results Tab in HB doesn’t really allow for that, this is due to the mesh not matching the values.
is there a way around that?
I’ve also attached an annual daylight image from IES as an example
Thank you,
Chris
