Hi, I just realised the HB Annual Load doesn’t have an input of “North”, unlike other recipes like daylight and PMV. Does it mean that I have to rotate the building such that the north is along the y-axis for HB Annual Load simulations?
I can add one if it becomes a pain point for a lot of people but it only takes a line of code if you want to change this now. You’ll just add a north_
input for the component and, at some point after this line:
… you’ll add:
_sim_par_.north_angle = north_
As luck would have it, I was already refactoring this component today in order to add support for Process loads. So I added in a _north_
input that functions just like all of the other _north_
inputs.
You should be able to get the update with the LB Versioner before the end of today.
