HB apertures by ratio
Hello everyone,
I am trying to create glazing by ratio for parametric study. When i tried to connect basic HB room to apertures by ratio component it seems work correctly but doesnt generate the glazed surfaces. Do i need to use extra component for the new LBT? Because i was simply using these components to create glazing by ratio in the old version.
Any suggestions?
Hi @feyzas
If you want to show the window to you, you can check their existence in two ways.
Vizualize.gh (22.5 KB)
oh thank you @Mohammad.hakim.a i didnt know about the new component! :slight_smile: cause normally we were able to see the geometry directly on the screen in the earlier versions i thought that there was a problem
