In this layer you will find sublayers under the Air Room layer. because I want to make the clusters of the air room. because each air room is not going to get combine they should be separate. Maybe I am not able to make data tree correct.
Please help
I would suggest constructing the rooms using HB Face components, as this provides greater flexibility in defining individual surface properties, particularly Air Boundaries.
When you set the Air Boundary option to True at the HB Room level, all eligible interior walls and floors between adjacent rooms are treated as Air Boundaries. This is why you were previously getting Air Boundaries for all interior walls and roofs, rather than being able to specify them individually.
Instead, try the following approach:
Decompose the room geometry and construct the rooms using HB Face components.
Explode the geometry so that individual surfaces can be identified and assigned the required properties.
Define the surface types individually, specifying which walls should be treated as Air Boundaries, Interior Walls, and Interior Floors.
I tried implementing this approach using your model by creating separate Interior Wall, Air Wall, and Interior Floor surfaces.
I hope this approach resolves the issue and gives you better control over the Air Boundary assignments. Let me know if you encounter any difficulties while implementing it.
