HB PMV and LB PMV
Hey! I want to analyze indoor thermal comfort. What is the difference between using LB PMV and HB PMV methods for calculation? Thanks!
It’s the same exact PMV model in both places. The Ladybug component just takes the 6 inputs to the PMV model and gives you the PMV. The Honeybee one takes a fully detailed Honeybee model with all of its energy properties and gives you a spatial map of PMV over the year.
Ok, thank you for your answer. I have got it.
