# HB PMV Comfort Map - Accepting CFD Inputs For Air Speed
**URL:** <https://discourse.ladybug.tools/t/hb-pmv-comfort-map-accepting-cfd-inputs-for-air-speed/20636>\
**Category:** feature\
**Tags:** comfort-map, thermal-comfort\
**Created:** [January 19, 2023, 2:52am UTC](https://discourse.ladybug.tools/t/hb-pmv-comfort-map-accepting-cfd-inputs-for-air-speed/20636 "2023-01-19T02:52:32Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![chris](https://discourse.ladybug.tools/user_avatar/discourse.ladybug.tools/chris/32/10179_2.png) [@chris](https://discourse.ladybug.tools/u/chris)\
**Post date:** [January 19, 2023, 5:35pm UTC](https://discourse.ladybug.tools/t/hb-pmv-comfort-map-accepting-cfd-inputs-for-air-speed/20636/2 "2023-01-19T17:35:18Z")
</div>
It’s not too difficult to do this since we already do it for the UTCI mapping recipe:
> [@UTCI. Accounting for both external glazing and point-by-point wind speeds](https://discourse.ladybug.tools/t/utci-accounting-for-both-external-glazing-and-point-by-point-wind-speeds/17600/10):
> Ok, I just merged a version of the component that can accept a folder of air speed values that align with the sensors. After you run the Versioner and restart Rhino, you’ll see that you can plug the folder into the \_wind\_speed\_ input of the recipe: … and this is what the folder should look like in relation to the model sensor grids: It looks like the Edddy team did a good job making it easy to run OpenFOAM simulations when the meshing isn’t complex and everything …
But no one had asked for it with PMV until now.
If you confirm that you can test it and you have a project where you’ve run CFD simulations to get a matrix of hourly air speeds for each sensor, then I’ll try to add this as soon as I get the chance.
_[View the full topic](https://discourse.ladybug.tools/t/hb-pmv-comfort-map-accepting-cfd-inputs-for-air-speed/20636)._
