HB set ldeal air loads parameter
Hi, guys, do you know where is the HB set ldeal air loads parameter component in the latest HB 0.063 version?
@hc2011301539 ,
All of the capabilities that were under the “set ldeal air loads” component now exist under the four primary HVAC components:
Assign HVAC System
HVAC_Air_Details
HVAC_Cooling_Details
HVAC_Heating_Details
Just make sure that the system that you assign to the zones with the HVACSystemsList component is Ideal Air and everything should work as it did with the previous “set ldeal air loads” component.
