HB_Split2Floors - Rhino 7
I believe i’ve found another component that is not compatible with Rhino 7. The HB_Split2Floors complains about:
One of the masses is causing a problem. Check the output for the mass that causes the problem. > You should consider breaking up this mass into smaller pieces.
Runtime error (ValueErrorException): too many values to unpack
Traceback:
line 361, in main, “”
line 386, in script
Needless to say that the same definition works fine in R6.
