Hi everyone,
how can i change met and clo values when i using HB UTCI comfort map?
Hi @msenalp ,
Clothing is not an input for the UTCI model. If you research how the UTCI model was created, they observed how people adapt their clothing to the outdoor conditions when they go outside and created a best fit curve for it:
This curve is hard-coded into the UTCI model and it cannot be changed. If you want to explore outdoor comfort with clothing levels that are not adapted to the current outdoor conditions, I recommend using the PET Comfort model instead of the UTCI model.
