Hi Everyone and as always thank you for your work with ladybug.tools world!
I have noticed that if I want to compare two hdr images that come from sky models the component “HB Visualize Sky (1.4.0)” doesn’t allow me to differentiate the name of the generated hdr image; as consequence, if I want to compare two images Image viewer (and before also the AdjustHDR component) will show me always the same image because overwritten due to the same filename.
I added a couple of simple strings (maybe these are not so elegant but they works
then I did the same with AdjustHDR component just to be sure that the final files (often I use the GIF format) have a different filename. If you modify HB visualize sky you can avoid this last amendment.
Finally the comparison at the same time of the two images:
Anyway, I hope this post could be just a simple tip (useful?) for someone.
Best wishes,
