Hi, I am fairly new to grasshopper and i am learning my way though it by doing one of my study projects,
Thank you for your work.
My question is how can I get cdd and hdd output from my epw file in ladybug,My teacher asks for it
and i need the output of it,
There is no direct output for HDD/CDD from LB components. But the can be easily calculated if you know the base temperature for them (say 18.3). Then you need to take the temperatures from the EPW each hour and count the degrees differences from this base.
You can use the Ladybug_CDD_HDD component under 1 | Analyze Weather Data tab
Forgot about this one … sorry.
