Honeybee and optimization with Wallacei
I am not sure if I should address this problem in this forum, but maybe you encountered a similar problem.
I am using Rhino 7 and LTB plugin 1.6 of Ladybug tools. I am doing energy and daylight optimization (multi-objective optimization). I wanted to test Wallacei plugin for Grasshopper.
It seems the Wallacei creates some problems with Honeybee.
When I run the Wallacei, it changes the decimal separator from “.” to “,” in Honeybee nodes and the simulation doesn’t run.
Did you encounter a similar problem?
I would appreciate any suggestions on how to fix this problem.
Many thanks!
Best regards,
Julia
