Honeybee annual daylight analysis
I am doing annual daylight analysis in honeybee,
after running the completed script, It shows no result found.
how to solve that issue.
previously i have done grid based daylight simulation, but here am not able to find any solution
thank you
Arpan Jain
annual daylight analysis.gh (617.1 KB)
Hi @Arpan,
Kindly use a profile picture. The avatar is supposed to be temporary.
You need to closely look at the occupancy generator in your file. The Honeybee_Read Annual Result 1 is not accepting your schedule. If you disconnect it, your file works.
thanks sir,
but i am not using occupancy generator.
i am re sending my file with only required script.
regards
annual daylight analysis.gh (547.0 KB)
On this forum, and in this community, everyone is on the first name basis. No one to be addressed as sir or madam please. :sunglasses:
When you do an annual simulation, you need to use the annual_analysis_files output. You can visualize the results like so. I used a large grid size to run the simulation faster. Your results will look different from this.
Thanks devang
i wasn’t aware about “honeybee_read annual result” script
this solved my problem.
