Honeybee annual lighting simulation issue
Hi, there are some problems with Honeybee annual daylighting simulation. The building is a opaque box with a daylight atrium at the center of it. The daylight atrium is surrounded by glazing windows.
Brep is used to connect the building elements to the Honeybee simulation object.
If The Brep is only connected to the walls and floors, the simulation will only be done for the first floor. All the upper floors have a DLA of 100%.
If the Brep is connected to all the elements: atrium, roof, walls, floors, there will be an error shown on the simulation unit which says “Solution exception:'Brep object has no attribute ‘split’”.
brep2%20result
How can I solve the problem?
Thanks in advance
Ruoxiao_text_v13_kk.gh (554.3 KB)
