HoneyBee - data not being transferred from HB grid
I’m new to using Ladybug/Honeybee and I am running into an issue where I am trying to generate a grid from a single large space, but the grid doesn’t transfer the data across to the next components.
Here is the grasshopper file: Daylighting_Analysis.gh (130.7 KB)
And here is the rhino file: Uploading: Daylighting_Analysis_Masterfile - 2.3dm…
Thanks
Your .gh file is no longer available here but I would guess that this is because your Room has no floor Faces for some reason. I suggest either editing your room or using the “HB Sensor Grid” component to construct your rooms instead of the “HB Sensor Grid from Rooms” component.
