Hello!
So I have a building which already exists. It has quite a complicated floor plan, because it is built out of two spirals, that lie in another. So there is not really a first or a second floor. Of course this will influence the daylight, that is coming in. I am quite new to honeybee, so I am not sure what would be the best way to do this simulation. I would love a solution that analysis the whole building in one run. This actually worked with one of the example files from hydra, but it couldn`t visualize the data, because of an error “number of results not equal to number of meshes”. What can I do about this?
And is it even possible to analyse the whole building the way I did, or is there a better strategy?
When I ran the example file it worked all out perfectly fine.
Greetings and thanks a lot!
ECO_ParkhausBestand_Sonnenstudie.3dm (429.7 KB)
Honeybee_Grid-based_Daylight_Simulation_Example_II_modified.gh (515.0 KB)
