Hi, I encountered the issue when I tried to run an illuminance simulation with honeybee and it seems like it does not see the geometry that blocks direct sunlight. In that case the roof. Any tips?
@ksawery.marszalek are you able to share your model and your script?
If you cant share it directly on here, using a 3rd party application like google drive, WeTransfer etc will work.
@ksawery.marszalek I added some windows to keep things from all being blue:
I made a honeybee room, assigned the overhangs as shades.
geometry_issues_radiance.gh (61.4 KB)
Hopefully that is of some help
Thanks, @TrevorFedyna , that helps a lot. Do I understand correctly that you recommend the HB room method and do simulation by zone rather than face-by-face?
@ksawery.marszalek I think that using rooms is a good best practice where possible as there are a number of checks along the way that can prevent the occurrence of defects along the way.
In your case doing sims on a classroom, HB room is the way to go I believe
I see, thank you very much for your help!
