Honeybee dynamic shade error
Hello all,
I follow this Dyanmic shading analysis example.
007_annualDaylightAnalysis_II_dynamicBlinds.gh (344.4 KB)
But I have two questions.
1.Annual profile files are not provided.
The result will be only calculated for the original case with no blinds.
2.The value of sDA has not change.Because I set dynamic shading, SDA should be changed.
9_16_dyanamic shade.gh (696.9 KB)
Thanks!
In my case, the annual profiles were created. Enable and Disable Honeybee_Lookup Daylighting Folder. As per output description on sDA on Honeybee_Read Annual Result I, dynamic blinds are not considered in the calculation of sDA.
Thanks for your reply.:grinning:
