Honeybee, image and falsecolor issue
If I try to conver a .png file in .tif the Honeybee_image_convert component works:
If I try to convert .tif image in .hdr it doesn’t work:
The error message reports: “1. Failed to genearate the .gif file. Open the bat file with a text editor and change the last line from exit to pause. Then run it again and see what is the error. here is the file address: …”
If I try to use Honeybee_falsecolor component with an .hdr file it works properly but when I try to convert the output from .hdr in .tif it doesn.t work:
The error message is the same:" 1. Failed to genearate the .gif file. Open the bat file with a text editor and change the last line from exit to pause. Then run it again and see what is the error. here is the file address: …"
Can you help me to solve this issue?
I update this topic with test access:
I have also tried to change the last line from “exit” to “pause”.
with this feedback I have changed the folder for the tiff file and it works now.
