I’ve been trying to Run HoneyBeeEnergy Modeling Script. I keep getting too many values to unpack on the Honeybee_Indoor Radiant Temperature Map.
Usually when this happens it’s a versioning problem in this case the component has not been updated since 2014. However, the IndoorViewFactor has been updated and does not correspond with the inputs for Radiant Temp Map. I attach the files for your review if you have some time to impart your insight. I left both versions of the components in the Script.
HoneyBeeEnergyModeling_HELP_msr.gh (611 KB)
Site_Ladybug_Shadow_Forum Post.3dm (172 KB)
