I am running into a problem and can’t find a solution in the forum:
In the Indoor View Factor Calculator component, when I have plugged in my zones and toggle _buildMesh to ‘true’, I get the error message:"Solution exception:‘Mesh’ object has no attribute ‘Vertices’.
There was some advice in the comments of http://www.food4rhino.com/project/ladybug-honeybee?ufh&page=1 to replace .Vertices with .DuplicateVertices() in the python script editor, but then I just get this message: “1. Solution exception:‘Mesh’ object has no attribute ‘DuplicateVertices’”.
I’d love to get this component working, I really need to visualise comfort and temperature data over surfaces in building!
Rhino 5 SR5, GH0.9.0076 and have updated LadyBug and Honeybee and all components.
I really appreciate your simple file that focuses on just the issue at hand. I can verify that the file is working on my machine and that you are getting the issue because of your version of Rhino.
I am nearly positive that the component would work as-is if you update your Rhino to the most recent Service Release (SR 12) but I think that we can find a good workaround in the meantime if this is difficult.
Can you let me know if the component in the attached file works with your SR5 version?
